Home › Forum › Ask A Member › Battery powered ignition
- This topic has 17 replies, 5 voices, and was last updated 3 years, 1 month ago by
Jeff Heise.
October 2, 2023 at 11:24 am #281205
Recently aquired a omc serial number 4010715 i damaged one of the plug wires trying to remove the plugs is there a replacement coil available? also mounting bracket is broke on one end , never dealt with battery ignition before what kind of battery would i need ? Can send pics if needed
October 2, 2023 at 12:16 pm #281206
Manny of us use this type of battery-
https://www.ebay.com/itm/222528177276?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=FmWitaJLQCa&sssrc=2047675&ssuid=_-YLkpExSsW&widget_ver=artemis&media=COPY
You can repair your coil using this coil-
https://www.ebay.com/itm/232218550107
using this procedure-
Video – 1 https://www.youtube.com/watch?v=e2vxDqF_OEU
Video – 2 https://youtu.be/xwbTlC1xIlA?si=_Yfb1wQD6iV513Tx
October 2, 2023 at 12:21 pm #281207
Too many links to post at one time makes a reply disappear –
TubsA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
October 2, 2023 at 12:25 pm #281209
October 2, 2023 at 12:29 pm #281210
Video – 2 https://youtu.be/xwbTlC1xIlA?si=LH2evmyYCLhJG24K
Your coil tube is smaller but I think this coil will fit.
October 3, 2023 at 12:38 am #281252Tubs,
Great instructions except it calls for 10 ohms resistabce, more like 8 to 10 K. ohms. Also when I did industrial electrical the soldered, bolted together connections it was wrapped with cambric tape (insulating) tape before using blsck Scotch 33 tape for better insulating compaired to “Jap Wrap” tape to improve connections. Also clean the soldering tip & pre tin for faster heat conduction. For single cylinder apps ground onespark plug wire for a much hotter spark.Super video for beginners!!
October 3, 2023 at 12:09 pm #281208.
October 7, 2023 at 8:23 am #281397With no pictures I am not sure which coil you have, but guessing it is the one that has 2 brackets on the outside to use to attach to mounting bosses on the motor….I do 3 d printing and I am currently designing Resin printed tube to allow a modern coil to be installed that will fit in this application.. I have 2 motors here one is a 1934 Speeditwin, the other is a 1933 Elto Lightweight Model # 444. Both use this type of coil…
The system will allow easy access to let one replace the coil, plug wires and such without dealing with that blasted nasty tar…
I am making progress…
Cheers
Richard
classicomctools@gmail.comOctober 7, 2023 at 10:55 am #281398
Best guess, going by ” battery ignition” and the number posted,
leads me to believe he has a model 401.
October 8, 2023 at 8:46 am #281428With no pictures I am not sure which coil you have, but guessing it is the one that has 2 brackets on the outside to use to attach to mounting bosses on the motor….I do 3 d printing and I am currently designing Resin printed tube to allow a modern coil to be installed that will fit in this application.. I have 2 motors here one is a 1934 Speeditwin, the other is a 1933 Elto Lightweight Model # 444. Both use this type of coil…
Cheers
Richard
Will post pics later todsy
