Home › Forum › Ask A Member › Anyone seen something like this before?
- This topic has 41 replies, 24 voices, and was last updated 9 years, 7 months ago by
garry-in-michigan.
March 23, 2017 at 10:28 pm #54776March 23, 2017 at 10:29 pm #54777
Didn’t find said Cross Radial on YouTube, but did find a neat
video of "a" radial engine running.
I think one of the cylinders is missing, but not sure
which one. 🙂Prepare to be boarded!
March 23, 2017 at 10:59 pm #54778neither of those motors are mine
The one on the boat belongs to an AOMCI member in Florida, go look at the page to find his name. AOMCI home page, Photo Gallery. It’s there.
The heavily and overly customized Cross, that is painted black with plated cylinder heads, well I have an opinion on it, but that’s all I’ll say about it, except to say that I had a conversation about it with its most recent owner (now deceased) who told me this motor was "very pretty" on the outside but full of gunk and "evaporated oil residue" on the inside…. thus, bringing to mind the old adage "don’t judge a book by its cover"…. nuff said
Best,
March 24, 2017 at 1:19 am #54787March 24, 2017 at 2:08 am #54793This is why I love this hobby…… so much variety!
Found a video of the Riley engine running…..
https://youtu.be/NxYwCLEiDew
Thanks Garry!Prepare to be boarded!
March 24, 2017 at 2:43 am #54798March 24, 2017 at 11:14 am #54801Well, this is truly an amazing find for sure….
March 24, 2017 at 12:50 pm #54803The prop on the Black Cross is backwards because it has the quite rare tractor racing lower unit.
classicomctools@gmail.comMarch 24, 2017 at 2:09 pm #54806Let me throw this at the wall, so to speak. First, the the orientation of the carb’s float bowl makes it a vertical shaft motor- so not an airplane motor. Second, the water cooling exit with the exhaust around the shaft is definitely a marine engine with a midsection of an outboard design. I would think that adaptor is the key. Does the "output " side match any of the high HP towers of the day? Finally, since the jugs are all parallel, it suggests a common connecting rod set with one beefy crankpin. Think of a starfish shape with pistons on each arm. Since the crankcase is shared, there would be no way to pull/push the fuel/air mixture- unless you employ a supercharger/blower to pressurize the crankcase. Does anybody else remember that McCullough invented a supercharger in the 1930’s? I would wager that the casing below the flywheel is a supercharger similar to the early Ford Flathead design supercharger. http://vs57.y-block.info/history.htm Any thoughts?
March 24, 2017 at 9:34 pm #54822Jet ? That doesn’t look like an impeller. Looks like a shrouded prop to me. I am reminded of Bourke cycle but the odd number of cylinders keeps me guessing. Wow.
Certified JB weld
