Home › Forum › Ask A Member › Anyone seen something like this before?
Viewing 10 posts - 11 through 20 (of 42 total)
  • #32452
      In one of your pictures, two condensers are visible, near to where the spark wires go under the flywheel. So I’m going to assume there are 5 of everything under there. Must be cramped.
      #32459
        With 10 magnets around the circumference of the flywheel, one coil and set of points could fire the plugs with the flywheel also acting as the distributer. A ridgid steel tube/pipe on bottom of the piston could go through a brass bushing in a plate at the base of the cylinder that would seal the crankcase and charge the combustion chamber while the bottom of the tube would connect to 4 connecting rods to the master connecting rod going to the fifth cylinder. That would account for the large crankcase. It almost has to be a one of a kind prototype.
        #32460
        ken-w
          Could it be the prototype for this?
          #32462
          cajuncook1
            quote rickrodt:
            I ran across this unusual power head and jet drive unit and am looking for any information concerning it, I believe it is a 5 cylinder two cycle radial engine. The flywheel has McCullough Corporation Scott Division stamped on the rim. Any help in discovering information on it would be greatly appreciated.
            Regards,
            Rick Eichrodt
            Rick, your motor would make an interesting article for the Outboarder.
            Thanks, for sharing.
            David T.
            #32473
            lotec
              Somewhere I have some photos of an aircraft drone with a Mac engine. I wonder if this is one of them?
              #32477
              Casey Lynn
                Don’t know about that…..would love to see a radial drone from Mac though.
                I remember 2-cylinder opposed and 4-cylinder opposed Mac drone engines but never a radial.
                They even had counter-rotating propellers on at least one of their engines.
                #54762
                  Regarding 5 cylinder radial engines.
                  Here’s an ad on EBay of a 1930
                  Cross Radial, 5 cylinder engine!
                  Would love to see photos of
                  an original one!
                    The cylinders look very similar to the one on my early 50’s Power Products AH-47
                    PM T2
                      on the AOMCI home page Photo gallery
                      #54775
                        PMT2 – Wow, that appears to be the same one as the 1930 ad, correct?
                        Is it yours? If so, do it run, and when can I see the video!
