Home › Forum › Ask A Member › Zephyr lower unit seal?
  • #6531
    wyo307
      Does anyone have any suggestions on what to do about a leaking lower unit (prop shaft) seal on my 1946 zephyr? It had a fair amount of fishing line wrapped around it that I believe ate the seal so that when I run it I get some grease coming out around the shaft. Is there a simple fix for this or does anyone have a lead on where another seal can be found? Thanks for the help.
      #54274
      aquasonic
        Time for a new seal. You need to find a parts manual for the 1946 Zephyr, find the part number, then get a cross reference for the updated version. Lots of helpful people on here. Someone will most likely help out with the information that you need.
        Improvise-Adapt-Overcome
        #54278
        wyo307
          Well that is the problem. From what I can tell it is 195564 "Gear Housing Cap & Bushing" but I have been unable to cross reference it anywhere. Anyone have any ideas? It may just be easier to post a for sale add I guess and I am assuming that I will end up with a whole lower unit just for that one piece of it.
          #54279
            The parts list you posted says the propeller shaft grease seal is part number 171526. marineengine.com say they have three of them in stock.
            #54282
            wyo307
              Wow that was a dumb overlook on my part! Thank you for pointing that out for me Frank.
