Home › Forum › Ask A Member › Year of Buccaneer?
  • #7255
      Anyone know for sure what year this Buccaneer 5 hp is,
      and if one of it’s OMC brothers use the same throttle
      twist grip assembly?
      http://www.do-bid.com/cgi-bin/mnlist.cgi?dobid30/7
      David Stanton
        Gale made 5’s all through the 1950’s and I’d guess that one is a 1955 or 56 , but I could be off a year or so. The OMC tiller/throttle handles from 1954 up into the early 1960s for 5 to 10 HP should interchange, (maybe the 15s and 18s also) although the ones from 1959 or 1960 up will look quite a bit different.
          Dave, much appreciated. Sounds like I have "options" in finding
          the part!
          retiredoz
            Handle’d be the same, the throttle gears may not be. At some point in the mid-50s the gears went from pointed to rounded, and they don’t mix-n-match..
            #59148
              Retiredoz, From the auction photo, it looks like the tiller shaft is in
              place, so I’m guessing the gears are also. Would be great if I just
              need to find the twist handle.
              fisherman6
                Make sure when you find a twist grip (assuming that is all you need) that it has the friction ring inside, unless you already have a spare one sitting around.
                -Ben
                OldJohnnyRude on YouTube
                #59168
                  Thanks for the reminder Ben. I was looking at different ones on EBay,
                  and didn’t consider the friction block.
                  Anyone have a parts diagram for a circa 1956 Buccaneer 5 hp?
                  Thanks!
                  wedgie
                    Does this look right Bucc ?
                    https://richardlpaquette.ca/5D12VManual.PDF
                    #59171
                      This tiller should work. It has the cast gear. The earlier stamped gear is part number 375977. . . 😀
                      #59173
                        Buck an ear – – – 😀
