Home › Forum › Ask A Member › Year/Model Identification? Sea King
  • #280319
    John Gragg
      I’m thinking about a 2nd motor already. Two biggest reasons:
      1.) If it’s the right year, could be a great parts motor for me or even use my motor as the parts box to put together one really great motor.
      2.) If my motor runs and I decide to just make it a patina runner, I can work toward a restoration on this one. Looks to be in great physical (appearance) shape.  You can see the pic of my gas tank, don’t think my motor will ever compete in the beauty pageants.
      Can anyone help with the year? The identification plate photo is attached, I don’t see anything where the model number should be but there is a serial number of 105016.
      5hp? 1.5? 3?
      Any help would be appreciated.
      Best Regards,
      John Gragg
      RIverside, CA
      Just starting in the hobby, please be patient.
      48 Sea King 5hp GG9014A. Sold
      49 Sea King 5hp GG9014A
      48 Johnson TD20. Sold
      49 Johnson TD20. Sold
      54 Johnson QD15. Sold
      55 Johnson CD12. Sold
      57 Johnson RJE-19M
      57 Johnson RDE-19
      #280329
      Steve Martin
        Can’t say for sure, but that is identical to my ’48 5hp.
        #280333
          Interesting that there is no model number on the tag. 5hp ?
          #280344
            How does the serial number compare with the one you have now?
            Gale made lots of those motors for Monkey Wards.  There are lots of gas tanks out there, some even not too badly bashed in.  (Example not mine)
            50’s Vintage Gale Sea King 15GG-9015 / 5 HP Outboard Motor Fuel Gas Tank | eBay
            #280347
            John Gragg
              Thank guys.
              Ralph, I noticed my motor (’49) has two horizontal slots in the front side of the lower housing right under the transom mount. The subject motor has one. Yours the same?
              Tubs, could that also be a 1.5hp? I ask because my motor uses a decimal point (5.0) in the hp description. Yes, it could have changed year to year, but trying to make some comparisons here.
              Frank, my serial is 324531. Looking at the chart on discount marine I am assuming that the column ‘serial’ is the starting serial number for that model run. I’m sure you have it but in case here it is: https://discount-marine-parts.com/ob_sea_king_gale_model.html
              Because of the missing information, along with the many models made each year, it’s really hard to tell what year it is. But very likely a ’47 or ’48. Definitely not a ’49 in my mind.
              I appreciate any additional input you might have and Frank, I will get to looking harder for a gas tank. How did you search it? I’ve used the part # to no avail. That tank will probably ‘work’ for my motor, with some fuel line adjustments, but is not correct for my motor. Gonna keep searching and hope for the best.
              Thx guys!
              Best Regards
              John Gragg
              RIverside, CA
              57 Johnson RJE-19M
              57 Johnson RDE-19
              #280350
              John Gragg
                This file didn’t make it 1st time
                John Gragg
                RIverside, CA
                57 Johnson RJE-19M
                57 Johnson RDE-19
                #280353
                John Gragg
                  Dang! I had 15 minutes into a reply and it just went away. Bear with me, I have a few questions/comments but my phone finger is numb. Gonna move to the garage computer in a few hours. Thx!
                  John Gragg
                  RIverside, CA
                  57 Johnson RJE-19M
                  57 Johnson RDE-19
                  #280356
                  John Gragg
                    Frank,
                    Amazing how many gas tanks you can find if you just search Sea King Gas Tank. I was searching by part#.
                    Does anyone have access to a parts guide for ’51 and above? Mine only goes to ’50.
                    Thanks All!
                    John Gragg
                    RIverside, CA
                    57 Johnson RJE-19M
                    57 Johnson RDE-19
