Home › Forum › Ask A Member › Wrist Pin Removal
  • #3071
    drifter
      I am working on a Sea King 5.0hp model GG8960A (Viking /Gale model 5D14).
      I must replace one piston so I need to drive the wrist pin out. (I’ve done this before and have built a fixture for my press)
      But….dang it, I’m getting old and cannot remember which way the pin must be pressed out.
      When removing the pin – do I drive the pin away from from the "loose" "L" side side and out the unmarked side? This is the way I remember doing it.
      Re-installing the pin from the "loose" "L" side to the tight side?
      So, whether I’m removing or installing the wrist pin – the direction is the same – from "loose" to tight.
      As always, thank you for the help.
      #27745
        yes, drive from the loose side to the tight side for removal and installation
        #27748
        drifter
          Thanks Fleetwin.
