Home › Forum › Ask A Member › Worn fuel tank fitting ID'd, + tank choice
- This topic has 15 replies, 7 voices, and was last updated 7 years, 3 months ago by
chinewalker.
July 23, 2019 at 11:44 am #179371
Amuller is correct. One pin lets air in while running, while the other allows fuel to be pulled from the tank, when the line fitting is attached thereby pushing the pins in. If the o-ring on the fuel outlet is worn, it can empty the tank in hot weather, if allowed. Doesn’t have to be in direct sun, but that sure accelerates the issue. It will get up to 110 F this week, at my house. Because I replaced the o-rings for the pins, the tanks did not leak when stored, even when hot. By not replacing the quad ring, as soon as the fuel inlet pin was pushed in, the leakage began.
I really hope this solves the issue. It should; makes complete sense.
I very much appreciate the help and knowledge.
Stay cool, y’all.
AlanJuly 23, 2019 at 11:48 am #179372That tank should not build pressure at all…should it?
Yes, they do build pressure. In order to comply with no-emissions laws, the tank has an one-way vent valve built in. It will allow air to enter the tank, but not escape. But an over-pressure valve will open before it blows up. Or so I’m told.
July 23, 2019 at 1:39 pm #179378xxxxxxxxxxxxxxxxxx
This reply was modified 7 years, 3 months ago by
outboardnut. Reason: found the answer to my question
August 3, 2019 at 7:18 pm #180683Yup! It was the o-ring, (“quad ring”) behind the small brass ring, where the pin protrudes. Did all three of my tanks today. I can see how this would let air in, while the fuel pump was pulling fuel up from the tank Hope this is the reason for the lack of power. I’ll post a clip if so.
Very much appreciated;
AlanAugust 3, 2019 at 9:55 pm #180693I played around with about 5 tanks this afternoon and most of them leaked around the valve stems. Initially I’d thought the leak was from the “o” rings in the connectors, but looking closely showed it was the valve stem seals in most cases.
Alan Muller
August 7, 2019 at 7:14 am #180874One of these days I want to source those o-rings from someplace other than OEM. BRP thinks very highly of their little bits of rubber. McMaster Carr must have them…
Has anyone already done that? Maybe offering a kit to do the whole fitting?
