Home › Forum › Ask A Member › Working on a 1955 evinrude 7518 7.5 hp. Problem when I screw down the retainging
  • #176752
    plymouth4
      When the retaining ring screws are tight I cannot turn the throttle shaft. Any help would be appreciated.
      Thanks plymouth 4. The retaining ring is flat side down, fits in the grove on top of the engine. When all four screws are tight I cannot turn the
      throttle shaft. Have checked the clearance on the screws and their is sufficient clearance. All holes in retaining ring line up with the mag. plate.
      When screws are loose the mag. plate will turn withe the throttle shaft. This baffle me.
      Thanks for any help. plymouth 4
      • This topic was modified 7 years, 5 months ago by plymouth4.
      #176754
      olcah
        Just guessing that you are referring to the 4 screws that hold the magneto plate down? In that case could the ring the screws go into be upside down? If you describe situation a bit more completely one of the fellows that know this engine well will come along and answer your question.
        #176756
          Did it work before you took it apart? Kind of sounds like somebody bent or dinged the brass magneto support ring in an effort to tighten up a wobbly magneto plate. You didn’t do that did you?
          #176763
            Retaining ring should be flat side up. As Frank noted, the brass support ring may also be bent.
            1982 Evinrude 25hp
            • This reply was modified 7 years, 5 months ago by Bob Wight.
            #176781
            plymouth4
              YES IT DID WORK. i HAD A WOBBLE IN IT AND TRIED TO STRAIGHTEN IT OUT. wILL CHECK IT OUT AGAIN. tHANKS FOR TH INFO. WILL KEEP POSTED ON PROGRESS.
              #176788
                The aluminum threaded retaining ring should be installed with the flat side up…Did you replace the coils? If so, I have found that some of the OEM coil screws are just a bit too long and can bind the mage plate….
                What did you do to “tighten” the wobbly mag plate? “Dimpling” the brass retaining ring is a very delicate process…The mag plate will bind if you were too aggressive…
                #176815
                plymouth4
                  Yes I did the wobble plate fix. probably was to aggressive. Will check and report back. Coils were replaced.
                  Thanks for the info.
                  #177012
                  plymouth4
                    Rechecked the support ring, straightened the support out and reinstalled, and it worked. But, still have the magneto plate wobble. Any suggestions?
                    Thanks for all the info.
                    Plymouth 4
                    #177045
                      Well, you might look for another mag plate….But, keep in mind, that the boss on the crankcase might be worn also….Does it wobble up and down, or side to side, or both?
                      #177151
                      plymouth4
                        Wobbles up and down and side to side. The boss on the crank case seems to fit snug.
