Home › Forum › Ask A Member › Wizard pressure fuel connector
  • #311143
    opposedtwin
      I have changed out the o-rings in mercury and OMC pressure connectors but not one for a wizard.
      Before I attempt to press/tap/beat the innards out of the housing from the hose end, is there a better way? Or does anyone have pictures of the inside parts? I have never seen pics one apart nor have I seen wizard parts diagrams.
      The port on the top is for fuel while the one on the bottom is for air. Both are spring loaded like mist connectors.
      Thanks for any help!
      Scott
      #311152
      RICHARD A. WHITE
        I destroyed a connector trying to get those out……ended up getting another connector….ugh plastic ball, damages very easy
        classicomctools@gmail.com
        #311205
        opposedtwin
          Thanks Richard. So the process is essentially like the OMC disassembly, correct?
          #311302
          RICHARD A. WHITE
            Well, remember I destroyed mine, so I can’t honestly say.. I ended up buying another fitting from the Gas Tank man…I hope it does not leak…lol
            #311305
              I found that a little “heat” via a bottle torch helped
              me disassemble my OMC fitting a lot easier.
              opposedtwin
                I agree on the heat! I have broken one of the little brass nipples on an OMC connector. Heat helps loosen things up a bit.
                #311682
                RICHARD A. WHITE
                  Check them balls… I think they were plastic no likey heat…lol
                  #311802
                  opposedtwin
                    Good tip! Maybe just hair dryer heat! No flame.
