Home › Forum › Ask A Member › Wiring Diagram Needed 1958 Bigtwin
  • #297917
    Anthony Migliaccio
      Good evening and Happy Independence Day
      Can someone help me out with a wiring diagram for a 1958 Evinrude Bigtwin 35.  Model 25936.  Electric Start, remote control, no generator.  My current harness on the boat side and motor side has seen better days.  The insulation on the wires and now the harness casing is deteriorating where it really needs to be rewired.  I will probably remove the motor plug and route the new wiring through the hole where the plug is.  Its not too difficult but a diagram with wire colors and gages will be helpful with the project.  The diagrams in the SELOC book are great but the diagram for 57-59 35’s has the generator.  Ive looked over the club resources here with no luck.  Any help would  be appreciated.
      Thanks
      Tony
      Anthony
      1957 Johnson 18
      1957 Johnson 18
      1955 Evinrude Fastwin 15
      1955 Johnson 5 1/2
      1954 Johnson 10
      1989 Johnson 2.5
      1994 Evinrude 3.3
      #297921
      Anthony Migliaccio
        My apologies for the impatient impulses.  I did find what I was looking for.  It just took some patience.
        Tony
        Anthony
        1957 Johnson 18
        1957 Johnson 18
        1955 Johnson 5 1/2
        1954 Johnson 10
        1989 Johnson 2.5
        1994 Evinrude 3.3
        #297927
          Glad you found what you needed, let us know if you have further questions.  It is very important to remember that the two “M” terminals on the key switch must not be used as grounds for any accessories, these are the two mag primary leads that get shorted together to stop the engine.  Using these terminals as a ground for some other accessory will fry your coils…
