Home › Forum › Ask A Member › wiring a kill switch on a 1963 Evinrude 18
  • #4864
    boatman
      Hi all,
      Looking for some instructions for wiring a kill switch on a 18 hp Evinrude. Should be pretty simple, but have never done one. One wire goes to a good ground, does the other go to the points? Do a have to pull the flywheel to connect the second wire?
      Thanks for the help.
      Paul
      #41106
        Both wires go to the points. There should already be two black wires connected.
        One of the two sets of points will always be closed (grounded)
        #41110
          What kind of kill switch are you installing? Is it a stop switch to turn it off, or is it a safety switch with a lanyard to turn it off if you fall overboard?
          The motor came with a stop switch, so the wires should already be there. If you are installing a lanyard switch, connect it to the same two wires going to the stop switch (leave it connected also)
          Neither type of switch needs a ground connection.
          #41143
          boatman
            Thanks Phil and Frank,
            I am looking to do the safety lanyard. It doesn’t have a stop switch installed, but I will look for the wires. I am putting it on a 50’s Flyin’ Flivver 8 footer that I just picked up and want the safety lanyard in case my daughters go overboard while driving it.
            Paul
            #41149
              The wires should be there. Or easy to put back if somebody chopped them off. (Why would anybody do that anyway?)
