Home › Forum › Ask A Member › Wire size in ’57 Lark external harness?
  • #6173
    mas
      The larger Red/Black are 4 gauge…but what size are the smaller yellow/blue/black/red? It looks like 12 gauge…but it might be 14 gauge??
      Thank you,
      Mas
      #51544
        Don’t know the answer, but just going by the current requirements, the only one carrying a high current is the Yellow (generator wire). It probably is 10 or 12 GA. Next would be the red choke wire 14 or 16 GA. The rest of them are low current and 16 or 18 can handle it.
        #51556
        mas
          All the secondary wires appear to be the same. The insulation measures 1/8 inch. I’m guessing 12 then?
          Mas
          #51557
          mas
            The writing diagram for ’57 only lists the values for the larger wires and does not specify size of the smaller.
            #51558
              Let’s just say there is no harm in having them too big, other than physical space requirements. I am surprised that the Yellow isn’t larger than the rest though, since it carries 10 Amps. Certainly no need for the rest of them to have 10 Amp capabilities.
              EDIT: I just looked it up. 16GA is good for 10 Amps up to 20 ft. max. So maybe it really doesn’t have to be as heavy as I think.
              EDIT EDIT: Here ya go, this is newer motor but electrical loads are similar
              upload photos
              #51602
              mas
                Great…Thank you Frank!
                It looks like the wires were tinned…is it a big issue to replace with non-tinned primary wire??
                Also, after closer inspection, I do have (as described in your diagram) a mix of 14 and 16 gauge wire. It was just very hard to determine that without suspecting wire size differences.
                Mas
                #51605
                  Tinned wire is less subject to corrosion and easier to solder. The corrosion issue is why it is preferred for marine use. But it will corrode too, if exposed to water, especially salt water.
                  #51613
                  mas
                    OK Thanks Frank.
                    I’m going with tinned wires! Not that the motor will see salt, but better & original.
                    Mas
