Home › Forum › Ask A Member › Wire gauge
  • #283538
    benji41
      Rewiring the starter cable wire and do not know amp draw of starter. What gauge wire to use for the positive and negative also wire from battery to solenoid and solenoid to starter switch.
      Jim Benjamin
      #283542
        Typically the battery cables are 6ga and the switch wires are 16ga.
        #283545
          a jumper  kit  (6ga)  for boosting cars   may be cheaper  and long enough if you need the 16 feet .. you can always add protection with heat shrink tubing over the wire pair.
          https://www.amazon.ca/TOPDC-Battery-Jumper-Cables-Gauge/dp/B073VHZVZY/ref=sr_1_20?crid=3SHTOWRKPH99X&keywords=6+gauge+wire&qid=1703860815&sprefix=6++gauge%2Caps%2C97&sr=8-20
          #283563
          JOSEPH BRINCAT
            Caution with the jumper cables, those and most are aluminum wire, not good for marine environment and can’t be soldered to terminal connectors. Suggest staying with copper.
            #283567
              good point yet these wires are coated  with copper   should solder OK no??    or simply crimped
              amp capacity  should be ok for small   OB starters and short distances
              OP can compare  cost/benefits  or  go copper   if only a  few feet   are needed.
              #283592
              ROBERT LAFAYETTE
                Brillman wire company sells battery cable by the foot. there may be cheaper sources out there.
                Home – The Brillman Company | Antique Tractor & Auto Electrical Parts
                Products Archive – The Brillman Company
                #283593
                  Copper coated aluminum?  Interesting.  Don’t know that I’ve ever seen that.  Would that be an electrolysis nightmare around salt water?  Just wondering.
                  #283602
                    certainly possible..benj41  can choose ..if  just freswater boating     around here we just eat the stuff  and  melt ice with it 🙂
                    #283654
                    benji41
                      Thank you all for your input and help. Now on my way to complete me starter wiring.
                      Benji
                      Jim Benjamin
                      #283657
                        Frank,
                        I had the copper coated aluminum cables on my 79 Cadillac & the negative cable fried the air conditioning dash controls, VERY  high resistance All GM’s more than likely to save weight for better gov fuel rating. (Junk!). Replaced with xhhw type wire & soldered my own terminals on. My 62 Chevy P.U. has the same for easy 30 years. Can be bought at electrical supply houses in any size. I chose xhhw for the best insulation. Mine was “rabbit” wire. Came from wire pulls that always ran away :)!
