Home › Forum › Ask A Member › Winterizing Wooden Boat
  • #301706
    Aidan Smith
      Working with a 1953 Blue Streak Utility, wondering the best way to store it for the winter, outside.
      I’ve heard many things, but as this is my first winter with the boat, I have no choice but to tarp it.
      I will be shrink wrapping it next winter.
      My thoughts was to build a frame that not only lets snow slide off, but lets air flow get over the wood to keep it dry.
      Any thoughts?
      IMG_1723-2-min-2-min
      1952 Blue Streak "B-Stock Runabout" - 1952 Mercury KG7Q
      1955 Feather Craft Vagabond - 1956 Mercury Mark 55E
      #301728
      RICHARD A. WHITE
        I believe it need covered, but not sealed up/shrink wrapped… it must be allowed to breathe. if not I think any moisture will start the wood to rot.
        I use Uncle Gus’s repellant, keeps mice away.
        Wood boats are different..
        classicomctools@gmail.com
        #301730
          turn it upside down so water wont collect in it.
          #301731
            If you have to store it out side, before you cover it, give it a coat of Thompson’s WaterSeal Multi-Surface inside and out. This is a water repellent, not a finish, and you would need to reapply every year.
            #301738
              I would keep it out of the sunny part of the yard to stabalize  the temperature swings … imho cold  wont hurt it much if the wood is not soaked.   think of  millions of canoes in camps  and    bush  lodges ……simply turned upside down for winter.     they last for  generations.
              #301753
              Aidan Smith
                Crosbyman,
                The boat will be on the south facing side of a garage, where there is little to no snow to begin with. It will be upside down on a cradle, and covered up, but the bottom of the boat will be exposed so that wind flow can swirl up and around. It is sealed mahogany, so I’m not too worried about rot, but just general care and precaution of the hull.
                #301756
                Gary H.
                  If you have the ceiling height in your garage, Harbor Freight sells a 400 lb. Electric winch with remote control for $100. Just make a nylon strap cradle and lift it up.
                  #301794
                  Aidan Smith
                    No need to worry about covering it now… I managed to shove it inside of a small guest house on the property. Inside space is 11′ front to back, the boat is 10’9″. Fits like a glove!
                    #301795
                    RICHARD A. WHITE
                      Would recommend HIGHLY some Uncle Gus’s to prevent little furry friends from making it their home for the winter.  Or something
                      #301796
                      Aidan Smith
                        I put a rodent repellent scent bag in the bottom, the same I use on my sailboat. Smells good and doesn’t leave any trace! Its better to know that the boat is safe inside for the winter though.
