Home › Forum › Ask A Member › Winter Project Chrysler 6 HP 62HA
  • #328549
    Jeff Barsch
      Shallow-Water
      I was helping a neighbor get his outboard running and he wound up giving me this outboard as a thank you.  He said it hadn’t been started in many years.  Since I had my tank set up for the other motor, I dropped this in the tank and after about 10 pulls she fired up!!  The pull start was wonky but thanks to Ben Dittmar’s great videos I have been able to get that corrected.
      She ran as long as the bowl kept was full, so I think the fuel pump diaphragm has likely hardened up.   Looking up the Model number, it seems this is a 1971 Model.  I looked on Marine Engine and saw that their cut sheets don’t start until 1976 so I want to make sure the parts diagram/part numbers match for this motor.
      Second question could someone confirm the shallow water bar is safe to be flipped down/utilized with the highest pin setting at the top of the pin arc.
      3rd question the decal for the tilt release is missing could someone provide a photo of what the decal said.
      This is my first Chrysler I have worked on so sorry about the newbie questions!
      Thanks,
      Jeff
      IMG_3491
      Model
      1954 Evinrude 7.5 HP
      1954 Evinrude 15 HP
      1954 Gale 12 HP
      1955 Johnson 10 HP
      1956 Johnson 10 HP
      1956 Gale 12 HP
      1956 Evinrude 5.5 HP
      1957 Johnson Golden Javelin 35
      1958 Johnson 7.5
      1960 Evinrude 18 HP
      1973 Johnson 6 HP
      #328690
      elgin2
        Try discount marine parts. Or Franz marine.
