Home › Forum › Ask A Member › White aluminum oxide powder
  • #4307
    SCOTT BOGUE
      A fellow member asked me how to remove the white aluminum oxide powder he was finding on his barn find motor. It occurred to me that I don’t know how, except to use steel wool. That has its own side-effects.
      Can this material be reduced to aluminum with a liquid, the way rust can be converted?
      Must it be mechanically removed? If so, what is best? Blast media?
      And finally, how can it be kept from coming back?
      Thanks.
      auldscott
      #36782
        i think plain vinigar can help….try googling for solution
        #36804
        dmbono
          I use aluminum brightener pump spray from NAPA- mild acid.
          #36830
          PugetSoundBoater
            Would that NAPA aluminum brightener work on the water jackets surrounding the cylinders to deal with salt water corrosion ? Do you need to nuetralize it after applying? I’ll have to check it out.
            Robbie Robertson
            #36836
              Vinegar is a mild acid – neutralized with backing soda.
              Garry in Tampa
              #36845
              archangel
                I was just reading this a couple of days ago:
                https://www.everbritecoatings.com/Quick … uminum.pdf
                The product is a protector, but the instructions are for pre-application cleaning. I found the info on Feathercraft.net where some members have used the process to refurbish anodized classic Feathercrafts.
