Home › Forum › Ask A Member › Which version of Gale built motor?
- This topic has 11 replies, 5 voices, and was last updated 8 months, 1 week ago by
nabmd.
March 2, 2026 at 8:54 am #305189
I have this small motor which was a roadside find in Snowmass, CO. Single cylinder, probably 2.5 or 3 HP (seems bigger than 1.5HP), cast aluminum 2 piece tank, separate fuel shut off under the tank, (not integral with the carb), pressed steel carry handle (not cast aluminum), silver/aluminum paint without any recognizable decal, ID plate missing from front of transom clamp. The only stamped number on it is on the freeze plug on front of crankcase, behind carb, 0067217.
March 2, 2026 at 9:26 am #305194Compare it to photos of Sea Bee, or whatever Hiawatha’s model was named.
March 2, 2026 at 11:56 am #305205Yes, I think Sea Bee or Hiawatha as Bucc said… Look for any remnants of paint. The color will give a hint of the branding.
Looks like a nice motor, congrats
March 2, 2026 at 2:24 pm #305213I’ve tried to find good pictures, but haven’t had much success. I’m leaning toward Hiawatha due to the mag lever handle being steel, not cast aluminum. Paint is as noted, uniform throughout. Does is look like a ’41-42 motor, or a ’45, ’46, ’47, ’48? Anyone have any pictures? Does the serial number help date it?
March 2, 2026 at 5:33 pm #305229nabmd, when you pull the covers off look for numbers on a soft plug. That might help with the year.
dale
March 2, 2026 at 8:37 pm #305235The only number that was stamped was on the front of the crankcase freeze plug, 0067217. All the other numbers were cast into parts as casting numbers. I’m thinking it is a Hiawatha 25-3258, 3 HP, ’45-46, Gale model #131. There was a side picture of that model in a 2021 post here, but the photo doesn’t show up when I search on my computer, but it does when I search on my phone!??? Unfortunately, the front tag is not visible.
March 2, 2026 at 9:37 pm #305236Here’s a photo that’s supposed to be a 1949 Hiawatha. Very close, but not identical to yours:
https://www.pinterest.com/pin/49-hiawatha-5hp–822399581927125629/
(more lines on the cowl, and lines on throttle lever).
Here’s a Sea Bee running:
https://www.youtube.com/watch?v=l2WmgeyOHyA
And some photos (of a later, reversible?):
https://www.aomci.org/forums/topic/goodyear-sea-bee-2/
http://www.omc-boats.org
http://www.aerocraft-boats.org1 user thanked author for this post.
March 2, 2026 at 9:43 pm #305237Drat, looks like the pinterest link doesn’t work. Downloaded the image and trying attaching it:
March 3, 2026 at 8:35 am #305247Most of the motors I find pictures of have a recoil on them. Mine has the carb instructions for Lean-Rich stamped into the front of the lower cowls, and no decal.
March 3, 2026 at 12:09 pm #305297Regarding rewind, sorry, I spaced out and searched for 5hps (tho Gale had the habit of making both “Standard” and “Deluxe” models, thru the years. In the 50’s they could be significantly different (different powerhead)).
Here’s a FB post with a 1947 Hiawatha 3hp (at a Museum in Galesburg!), which looks very much like yours:
http://www.aerocraft-boats.org -
