Home › Forum › Ask A Member › which prop to run?
  • #1633
    rickinfarmington
      Anyone out there have any experience running a Mark 55 on a 12 foot Penn Yan Swift. Wondering if the light weight of the Swift will let me run a 13 or 14 inch pitch two blade?
      Rick ❓
      #17209
        I would run the 13in. IF you will be setting up for just speed jack it up and you should be able to run the 14 in.
        #17216
        rickinfarmington
          This will be set up for a one time race at one of our boat meets. What do you have in your inventory?
          Ric
          #17230
            cup the prop and raise it so the cav plate is a little above the bottom. and raise from there. use a tach. 5800-6000 RPM’s would be right for that race.
