Home › Forum › Ask A Member › Which motor to purchase – if any
Viewing 9 posts - 41 through 49 (of 49 total)
  • #34328
    jimaz
      Pic’s of the harness.
        1958 Johnsons are among my favorites style wise.
        I got my introduction to working on old OMC outboards (I had no prior "wrenching" experience) from this series of articles:
        http://www.omc-boats.org/maxw.html
        (written for people looking for cheap power for home-built boats, *NOT* for people interested in interesting outboards for their own sake).
        "big twin" was the Evinrude’s model name for the basic version of the 25-40HP twins of the 50’s and 60’s, but is often used to mean both the plain and fancy versions of Evinrude, Johnson and Gale 25-40HP engines.
        #34351
        jimaz
          Thank you Phil B.
          Will give it a read. Am starting from scratch also.
          Trying to track down a factory service manual if you have any sources.
          Regards
          Jim
          #34367
            The most complete factory manual is this one:
            http://boatinfo.no/lib/johnson/manuals/ … on.html#/0
            (tho this copy is ungainly to use)
            There were also small manuals for each model/year.
            But your library may have seloc or clymer manuals that cover the basics.
            The parts catalog is great to have, but this will do:
            http://www.marineengine.com/parts/johns … del=RDS-20
            Something i didn’t learn until recently is the the parts on each diagram are numbered in recommended order for disassembly!
            #34368
            jimaz
              Thanks again Phil B..
              Have you had any luck finding a place to source a wiring harness. The plugs on mine are just okay and the wiring itself is way past it.
              #34369
                If you don’t want to rewire it yourself …
                http://www.nymarine.ca/wiringharness.htm
                #34375
                jimaz
                  Thank you for the post Garry. Will see if I can find a local electrical supply that can help me put together what I will need.
                  Great info and links on the nymarine site.
                  #34380
                  mercuryspecialist
                    Hi Jim,
                    I sent you a private message which you might find helpful.
                    Regards,
                    Joe
                    #34389
                      Jim,
                      The red Johnson book is the one I have. It leaves out some early 4 cylinder motors but that will not hurt your use for your 58. It covers that very well!
