Home › Forum › Ask A Member › Which motor to get?
Viewing 10 posts - 1 through 10 (of 26 total)
  • #7003
    cheetahgod
      My dad and I are restoring a 11ft class b utitly racer. Im not looking to race it but rather just mess around and have Fun. I want to put a nice vintage Mercury outboard on it. I like the kg7q and the mark 20 and 25. I want to purchase a restored motor. Also how reliable are these motors?
      Im not sure which motor would be the best choice and not sure if having neutral and reverse is important.
      Could I please get some suggestions?
      Thanks
      Jason
      #57644
        cheapest way to go is mark25. better than the mark 20. the KG7 Q is faster BUT much more expensive. no real need for reverse. neutral is good. just my opinion.
        #57645
          Dockbusters are cool, until you are parking them in a bit of a chop or wind. Then not so cool. Just my opinion! If you are not racing, I would pick a motor with a racing look/feel to it, but perhaps not necessarily a racing motor, and one that has a few conveniences. Just my thoughts.
          What is your budget? Obviously, some motors are double or triple in price than others.
          #57646
          cheetahgod
            Budget is 1200
            #57647
            cheetahgod
              Is the Mercury 60j expensive?
              #57648
                get a mark 25 and have a lot of money to run on. trailer also
                jw-in-dixie
                  I would say not larger/more hp than a Mark 25, which has shift. As Dave says, Neutral is nice for starting and getting settled in a small boat. Has separate gas tank – you can use a smaller one to save space and weight. I have run a B runabout with the KG7 off and on since 1952 – very reliable.
                  It has no neutral – start and go. Prepare to have fun!
                  #57657
                  metalman
                    Jason,
                    My family ran 22 cubic inch powerhead on a racing tower/lower unit for years. Very reliable, parts are readily available, and plenty fast on a hydro. We started with KG7 and really enjoyed the bump in speed and reliability of the "frankenmerc" set up. The next step up from there would be a 25ss speed wise.
                    Good luck and have fun!
                    #57666
                    jw-in-dixie
                      This is a Merc 200 (22 ci) on a KE7 tower and a KG7 foot. The KE tower allows about 3/8" more engagement, driveshaft to crankshaft. KG will work but might strip. On an 8′ runabout. Works great.
                      #57672
                      cheetahgod
                        I have the opportunity to buy:
                        Kg4h
                        Mark 25
                        Mark 20
                        Mercury 60j
                        Mercury kg7
                        Mercury kf5
                        KH7
                        KF7
