Home › Forum › Ask A Member › When a motor does overheat
  • #22422
    wiscoboater
      That’s pretty cool Mumbles. Sort of works on the same principal as a brake lathe. You Kanucks are good!!
      #22423
      jpatti75
        quote wannabe outboard guy:
        Most guys just put a sheet of 120 grit emery cloth on a piece of flat window glass and run the head over it in a figure 8 pattern. do this till the gasket surface is shiny and even. That’s the Mumbles method. I believe Fleetwin does it the same way.
        Yep, just did this with 220 grit wetland paper on a warped Mercury exhaust/water jacket cover recently. Took a good 30 minutes of elbow grease doing figure 8s, but it nice and flat … no more water leaks. Not a head, but the same principle.
        JP
        #22442
          quote Mr. Asa:
          I wanted to see the how the lathe attachment holds onto the head.
          Blocks are fairly easy to attach to the face plate but heads can present a bit of a problem. Usually I have to thread three of the bolt holes so I can use a stud arrangement for mounting. This way I can run a dial indicator across the surface and adjust as necessary before making a cut. I’ll see if I have some more pics showing how different parts are mounted.
          #22445
          vintin
            I’m surprised a light removal of cylinder glazing hasn’t been mentioned.
            #22471
            Goman
              I de-glaze one cylinder just in case I want to see if it makes a difference down the road. 😉
