Home › Forum › Ask A Member › What year is this monster?
- This topic has 5 replies, 6 voices, and was last updated 2 weeks, 3 days ago by
PM T2.
October 20, 2026 at 12:49 am #330296October 20, 2026 at 5:53 am #330300
Guessing 1914 or “maybe” later….
Odd part there looking like an accessory something back of the tilt quadrant..not seen one of those before.http://www.richardsoutboardtools.com
classicomctools@gmail.comOctober 20, 2026 at 9:39 am #330315October 20, 2026 at 10:01 am #330317If it’s really a “monster” maybe it’s a 3 1/2 HP RPM.
October 20, 2026 at 10:06 am #330319What Richard saw… that bracket. Was there an option or after market accessory for an underwater exhaust? The bracket looks like it would fit a down tube.
PS, yes , I just checked Arlan Carter’s book…underwater exhaust was offered as an option in 1913 Evinrude RBM , cost $5.00 if ordered on the motor or $7.00 as an accessory.
October 20, 2026 at 8:30 pm #330336it wouldn’t be the 3.5 hp version of an Evinrude, because one of the “tells” of that motor is the lack of a casting core plug between the mixer port and the spark plug.
The two-piece crankcase design suggests that its prior to the 1916 model year. I can narrow it down to 1914-15 at best, and its a two HP model B or model D. The compensator/shock absorber on the driveshaft tube is something that was first seen around 1914 and was most commonly found on the model B & D (non-reversing models).
The loop casting between the tilt quadrants is indeed most likely a support bracket for an underwater exhaust pipe. As Joe B stated, the underwater exhaust option first was available on the 1913 models. It could have easily been retrofitted onto a later motor, and was also probably available as an accessory but I’m too lazy to check my Evinrude catalogs at the moment.
Hope this helps.
Best,
