Home › Forum › Ask A Member › What size battery for electric start Fastwin?
- This topic has 10 replies, 7 voices, and was last updated 11 years, 7 months ago by
kennmatson.
March 30, 2015 at 8:31 pm #1066
What size ("group") battery do you use (or suggest) for an electric start Fastwin.
I’m working on wiring one up, and need to figure out what kind of battery to get, and what kind of terminals.
Thanks!
Phil
Yankee ChapterMarch 30, 2015 at 9:35 pm #13065What kind of ends do you have on your cables? "Group" refers to physical size. The commonest red battery boxes are sized to fit a Group 24 battery. But there are also ones to fit a Group 27. I’ll catch heck for saying this, but I go to Wally mart and pick out the smallest (lightest) one on the shelf–to heck with the "Group". The down side of doing that is you may have to charge it more often. Even then, it won’t be too often with a Fastwin. They start so easy, it doesn’t take much out of the battery. Besides, you will be surprised at how many amp hours they can pack into some of those small batteries. Compare amp hours to gallons. More amp hours, more "juice".
EDIT: The question pertained to a Fastwin. I’d be a bit more selective if we were talking about something like a V-4 or 6 with electronic goodies.
March 30, 2015 at 9:37 pm #13066Anonymous
No ends, or cables, yet…. The engine came without the boat side of the harness!!
March 30, 2015 at 9:53 pm #13069It’s nice if the battery has wing nuts, but no big whoop if it doesn’t. They do make adapters. But then you have to factor in the adapters with the cost of the battery.
March 30, 2015 at 10:55 pm #13072Anonymous
So a "U1" lawn tractor battery might do the trick?
March 30, 2015 at 11:33 pm #13074I have used a garden tractor battery on my "59 fastwin. Any of the smaller ones for me, light and easy to put in and out.
AKA Outlaw Outboards in Fallon, Nv
Now in Twain Harte, CaMarch 30, 2015 at 11:42 pm #13075I’ve used a garden tractor battery as well. Doesn’t seem to be hard to start and worst case, the rope still works too. If you’re not keen on rope starting it might be wise to get a little bigger, just in case.
March 31, 2015 at 12:08 am #13076Easy to carry? Two small 6 volt batteries wired in series …
March 31, 2015 at 12:47 am #13078Be careful with the lawn tractor batteries. The really cheap ones are just over a hundred amp and like to burn up starters. Use at least a 250CCA battery. I had a $40 battery burn up a brand new Kohler starter….bad day.
March 31, 2015 at 1:17 am #13079No doubt the more powerful mower battery will work, but just a little larger you can get a car battery with a whole lot more oomph. I currently have one in my boat. Not really feeling inspired to go out with a flashlight tonight to see what it is.
