Home › Forum › Ask A Member › What motor to look for?
  • #37652
    Leon
      I would not put a big Homey on that boat. Way to heavy. The weight alone will probably capsize that boat, A $$ first 😀
      Unfortunately, the best 4 stroke for that, is a late model.
      #37730
        quote 1946Zephyr:
        http://boatspecs.iboats.com/Fisher-Pier … e/57e12418
        says the 1962 bearcat was 232 pounds.
        In comparison:
        http://boatspecs.iboats.com/Evinrude__5 … e/57e10396
        says the 1959 Evinrude 50hp was 216 pounds
        Two 1955 evinrude 25’s would have been 258 pounds
        http://boatspecs.iboats.com/Evinrude__B … e/57e12664
        A 1958 Mercury Mk58E (45hp) was only 131 lbs:
        http://boatspecs.iboats.com/Mercury__MK … e/57e10827
        Some modern 4-strokes:
        Tohatsu: 209 lbs
        http://www.tohatsu.com/outboards/50_4st.html
        Mercury: 247 lbs
        https://www.mercurymarine.com/en/us/eng … ifications
        Yamaha: 249 lbs
        http://yamahaoutboards.com/outboards/Mi … ifications
        #37776
        Leon
          Wow, so basically, all 4 stokes are a bit heavy, even compared to the Bearcat. Yikes. This is exactly why I don’t have a 4 stroke on my boat. :-O
          #37780
            A 4 stroke has many more parts than a 2 stroke. Valves, cams, maybe push rods or followers, valve springs, valve seats & valve guides.
            Late model motors have aluminum blocks to get a little lighter outcome. The ignition & carbs are too upgraded to run cleaner on newer stuff too. Look for how well it is warrinteed too. No spell check any more?
            #37783
            vintin
              I would consider the Tohatsu 50 two stoke TLDI MD 50 in a short shaft version before I’d opt for the Tohatsu 50hp Four stroke.
              http://www.tohatsu.com/outboards/50tldi_spec.html
              #37787
                This (2014) page lists Direct Fuel Injection 2-stroke outboards allowed on Lake Tahoe:
                http://tahoeboatinspections.com/2-stroke-ban/
                Evinrude E-TEC (2-stroke DFI)
                Mercury Optimax (2-stroke DFI)
                Yamaha High Pressure Direct Injection (2-stroke DFI)
                (All look to come in "large sizes" only)
                Wasn’t able to spot anything about the Tohatsu DFI’s on Lake Tahoe….
                #37788
                vintin
                  quote Phil B:
                  (All look to come in “large sizes” only)
                  From the link you provided for Tahoe:
                  "If your watercraft/engine has a California Air Resources Board (CARB) Star rating on it, it is allowed on the Lakes of the Tahoe Region."
                  Tohatsu 50 hp TLDI® Benefits:
                  Air assisted direct fuel injection system that provides excellent fuel economy
                  Extremely quiet operation
                  Excellent horsepower-to-weight ratio
                  Lightweight and compact
                  Available in short (15”) & long (20”) shaft lengths
                  Ultra-low emission, EPA and CARB approved
                  5 Year limited warranty
