Home › Forum › Ask A Member › What kind of fitting
  • #280520
    mike n
      Helping a friend with his mercuries. I would like to know if anyone knows the name of these fittings that were used on mercuries and where to get them. We want to make our own fuel hoses . We have crimping pliers. Thank you
      mn
      #280567
      Dale
        Wrencho Mercury’s came with high pressure lines with special fittings.  I have changed two motors over to automotive fuel lines and they work fine.  Start at the carburetor and replace all fittings with barb style fittings and automotive fuel hose using some sort of clamps and the correct size fuel line.  You could add a filter in the mix also.  Pressure generated is only 15lbs or so and my motors run great!  JMHO
        dale
