Home › Forum › Ask A Member › What is…THIS?
  • #2026
    johnyrude200
      Found this extra plate on a 9.5 I worked on recently. Problem is that when you throttle up, it would hit the manual starter/rewind. I had to pull the mag plate, remove it, and everything worked as normal. Have never seen this on any other 9.5 motor before!
      #20215
        may be a neutral limiter. I am not a omc guy I know mercs
        #20216
        johnyrude200
          I was surmising that as well, would only allow for about 3/5th throttle (not even close to the top end for a 9.5 – high idle at best), but I humbly wanted to ask the experts.
          I will give a shout to Mumbles, Gary, t2stroke, Fleetwin, and FrankR for a P/N reference!
          Also what application was this used for? Fathers holding their children in check back in the day?
          Thanks again for your willingness to share your wealth of 1st hand experiences!
          #20217
          wedgie
            So you can’t rev it up too far in neutral
            #20218
            johnyrude200
              In forward, the limiter held it at 3200RPM. Sold this motor 3 weeks ago but felt it was noteworthy to the godfathers. Worked on 14-16 of the 9.5’s over the past 8 months, more interested in preservation of the motors –
              and knowledge
              #20220
                Offhand, I don’t remember seeing one like that. Wedgie, what model are you thinking of?
                #20221
                david-bartlett
                  Marine Engine shows it as a lockout plate. #42.
                  http://www.marineengine.com/parts/evinr … /40022.gif
                  #20227
                    Looks like it was only used a couple of years, 1970-71. Is the intended function to prevent the starter pinion from rising (starting) at high throttle settings? Strange that it should be interfering with WOT.
                    Somebody once told me that education is what you have left after you have forgotten everything you learned.
                    #20238
                    beerman57
                      Throttle restricter for children?
                      #20241
                      mike-stroz
                        I had something similar on a Scott Atwater that I had. It would restrict the speed when the motor was in neutral or reverse.
