Home › Forum › Ask A Member › What is this thing, attached to a Mercury KE4 lower unit?
  • #298051
      At first I thought it was some kind of home grown patch, but then I noticed that the casting fits the lower unit perfectly. Any ideas what it is, or was?
      #298056
      David Bartlett
        Bill,
        Mercury’s are not my thing, outside of the auto tranny models, so I have nothing to offer except curiosity like you!
        David Bartlett
        #298071
        green-thumbs
          My first guess is it may be a “repair” for a gearcase with damaged water pump cover threads or damaged case.
          Clever native craftmanship NOT
          factory. OR maybe something else. You may be in market for an as As made by Kiekhaefer
          gear case assembly if you open
          this can of worms up.
          KE4/Mark 7 are fairly common so parts are out there. Rarest
          old Merc is one that has all
          its original parts in their
          correct places,
          opinion with no cash value
          Louis
          #298076
          NATHAN KILLIAN
            US Junior Member
            That is almost definitely not factory to my knowledge, and I highly doubt that any sort of aftermarket part manufacturer would put those non-hydrodynamic u-brackets on their motors unless it is specifically designed for stripped threads.  Probably just a very well made home repair.
            #298077
              MY thoughts it is a hookup for a water hose for flushing.
              #298079
              NATHAN KILLIAN
                US Junior Member
                That would make the most sense, but I do not see anywhere to hook up a hose from the pictures.
                #298081
                  would be on the other side
                  #298105
                    The casting, removed. Water intake holes drilled through it.  It is a beautifully cast and machined piece, if homemade. The aft end of the gear case seems fine. Not at all broken like a Typical Mark 6.
                    #298109
                    Fastwin18
                      Could it be meant to keep fishing gear or weed from entangling the propshaft?
                      #298162
                      Sam M.
                        Maybe it was made by someone who knew that many older Mercury lower units are susceptible to breakage, so they make this piece to add strength and rigidity to the lower unit in attempt to prevent damage.
                        Another idea:  Does it act as a spacer between the propeller and gearbox?  If so, maybe something was wrong with the original propeller shaft and a longer shaft was available, so this was used to fill the gap.
                        Fastwin 18, good idea!
                        No matter what it is, it is certainly interesting enough to warrant being re-installed on the motor, in my opinion 😁
