Home › Forum › Ask A Member › What is it worth?
  • #275872
    Charles Kern
      Any ideas on what this Evinrude is worth. Seller States that it is not Frozen and has compression. Believes it is from 1915. See attached
      #275873
        any mdl # picture  drawings   ?
        #275919
        Charles Kern
          Sorry thought it was attached
          #275921
          Charles Kern
            Struggling to attach photo.
            #275930
              Maximum file size allowed is 2.44 MB.
              Sometimes you can’t attach the photo if it’s too big.
              Max is 2.44 MB
              CHUCK
                This time it is not a matter of the file being too big.  It is a website issue of some sort
                Click the link to see his picture on Imgur
                https://imgur.com/a/O6OdWGc
                #275954
                  Well I’ve had 2 of them. lets start with the gas tank.
                  Little chance of finding one. Most likely bushings and
                  shafts are worn out in the gear case. Good chance water
                  has been left in the gear case at some time. Gears – water
                  pump cam rust pitted. Water pump piston worn out. Reverse
                  mechanism worn out and possibly welded together. Is it
                  there? I don’t see a tiller. Coil is no good.
                  Twisted drive shaft from hitting something. Crankshaft
                  key way damaged from flywheel coming loose. Bent
                  crankshaft from motor falling over. Rusty carb mixture
                  screw. Parts missing? If you don’t have or know someone
                  with machining capabilities that can make some of these
                  repairs the cost to have them done exceeds the value of the
                  motor, plus you still have the gas tank and drive gears,
                  if they are bad, to deal with. When looking for parts, they
                  were expensive.
                  When I had parts to sell I couldn’t find anybody who
                  wanted them. If it was offered to me for $50.00 its 6
                  of 1, half a dozen of the other if I would take it .
                  #275958
                    Tubs,
                    In Arizona there is very  little water. I never found a motor like that to restore.Looks like it’s maching shop time. I did have acess to one years ago & needed it for my 1942 Dodge powerwagon. Drive line headaches but it had a transplant to a 318 v-8. I could buy yokes for the driveshafts but the O.D. needed to be turned down to fit the trans.
                    #275959
                    JOSEPH BRINCAT
                      A lot depends on where you are located, in MI, IN, WI, these RBM’s and parts motors are not rare. Your example looks to be pretty complete but “crusty”. If it’s not stuck or have other major issues, I would think about $100 or so. Just keep in mind what Tubs said, you will likely need some metal working help to get it back to running condition, let alone restored.
                      #276045
                      Charles Kern
                        Thanks to all for your responses.
