Home › Forum › Ask A Member › what is it 4hp lightwin 2001 510 82
- This topic has 15 replies, 6 voices, and was last updated 5 years, 9 months ago by
HARRY D. NICHOLSON.
February 6, 2021 at 3:58 pm #229675
can’t find a yeard # for the plate ID hood says 4 hp
plated switched maybe… but what is it ???
This topic was modified 5 years, 9 months ago by
JACQUES.
February 7, 2021 at 5:49 am #229709I see you have no replies at all, so I will….I am confused. If the motor has no number plate, what’s the number in your thread’s title and where did it come from? Is this a fiberglass hood Lightwin or something much older?
February 7, 2021 at 8:55 am #229721fiberglass hood slanted ….those are the only#s on the side ID plate ??? will look furthetr and send pics later today picked it up on KIjiji (our craiglist) for 75$cdn
I initially & wrongly assumed it was 5hp… because it has a counter rotating prop like a 5hp ….. but marked 4hp on the front of the hood I had not looked closely enough at the ad before my bid
maybe it is a 5hp with the wrong hood ??? it is the non shifting version (rotates 180)
bottom HS speed neeedle is pointy like a LS needle ??? usually they are much blunter (maybe someone installed the wrong needle & it is missing the front knob π )
it has the round recoil spring on the side of the PH like a 4hp
February 7, 2021 at 10:15 am #229734Post a picture, the model number you gave doesn’t seem right..
February 7, 2021 at 10:59 am #229747see pics
This reply was modified 5 years, 9 months ago by
Mumbles.
February 7, 2021 at 11:02 am #229752February 7, 2021 at 11:32 am #229763Well, isn’t this interesting as your motor is a ’71 four horse and it has the correct needles but the 2001 model number identifies it as a ’51 – ’52 25 horse. It looks like the tag has been pop riveted on to so this motor may have a shady past.
Take a look at the Welch plug on the block and see what numbers are stamped on it, if the plug is still there.
Mumbles.
February 7, 2021 at 11:44 am #229768seller looked shady also… π claims he knew zilch about outboards…and I do not think it was grandpa’s
ho well it is mine now to play with before ice out π glad to hear the needles are kosher HS one looked funny
going to marineengine.com π ……………… they have several versions of the 4hp in the EV line
thanks ………….will look at the plug it is there ok
hood logo is correct… and I scanned all of those 4hp years and did not spot the 71 logo identical to mine. good eye Mumbles
JACQUES.
February 7, 2021 at 12:18 pm #229783Yep, that is a 71 4hp Lightwin, and that ID plate sure looks like it has been pop riveted in place….
February 7, 2021 at 12:38 pm #229786 -
