Home › Forum › Ask A Member › What does a Michigan K-42 propeller fit ?
  • #296363
    daytonajohn
      I haven’t found out which Mercury outboard this fits on.
      #296364
      CHUCK
        I’m out of town or I’d look it up in my copy of Arnold Cohn’s book.  . His info. was from Michigan Wheel catalogs 1946 to 1969.
        I can check tomorrow and let you know if it’s in there.  I assume you have looked through the Michigan Wheel catalogues themselves.  Oddly;  various propellers do not appear in their own catalogues.
        Michigan Wheel catalogues are in the Inner Sanctum.
        #296367
        daytonajohn
          Thanks SeaKaye12. I have looked at some of the Inner Sanctum catalos without luck.
          #296368
          Dale
            Daytona, K40, K41,K43 K44  are all 1947 to ’53 Mercury 10hp propellers.  Some are brass and some are aluminum.   All are in the 7 1/2″ x 8, 9, 0r 10″ pitch.  Yours is probably in that mix somewhere.   Hope this helps!
            dale
            get’em wet…..don’t let’m set!
            #296370
            daytonajohn
              this eBay auction for a K42 clearly shows the part number K42 stamped on it. I contacted customer service at Michigan Wheel, and K42 is not listed  in their obsolete inventory.    https://www.ebay.com/itm/267174955850
              #296386
              daytonajohn
                K42 is 7 1/2 x 10 1/2 same as the K40 for KE-7 1947-50 & WG-7 1950-53.  My answer man’s memory thinks the KE-7 has a shear pin propeller shaft and the KF-7 and KG-7 have the spline shaft.
                #296389
                CHUCK
                  That e-bay listing looked good until I see the $34.50 for shipping.  I have no record of a K-42 in the resource I have available.
                  #296426
                  daytonajohn
                    thanks to all who have replied! John
                    #296429
                    green-thumbs
                      9/16″ bore would fit KE4, Mark 7 and KE7. A 5/8″ bore would fit KG7
                      and KG4. KF7 had toothed clutch so
                      both prop shaft and prop have spline and notches…can be converted by changing prop and shaft to use shear pin,
                      K40 and K42 may be same diameter and pitch with different blade
                      area or profile. Owners also
                      bored out or sleeved to use on
                      unintended motors. I have a K42
                      that had been drilled out to 5/8″ I had bored and sleeved back to
                      original 9/16″. I believe Michigan Wheel probably knew best
                      because they tested and suggested
                      boat and motor applications.
                      Mercury went much further, testing props, boats and Mercury
                      outboards and issued Boat House
                      Bulletins so dealers could sell
                      proven combinations.
                      my much overprice 2 cents worth,
                      Louis
                      #296450
                      daytonajohn
                        excellent post ^
