Home › Forum › Ask A Member › What are the year-appropriate instruments for ’50s era outboards?
  • #6270
    mr-asa
      Saw someone post about Airguide tachs the other day. I got to wondering what other instruments were popular and common at the time the ’50s motors were popular. I’m still looking for odds and ends to flesh out my Herter’s, and I figured a tach or speedometer might be fun.
      So, what would work for a ’56 or ’57 boat?
      #52424
      wiscoboater
        Spedo, Tach, Volts and Fuel. Thats about all was used back then. Even today thats the classic arrangement for an outboard. If you had a really high end motor, Trim gauge?
        #52430
        WAYNE
          Often they used an ammeter and not a volt meter. In the 1960’s OMC also had overheat gauges.
          Wayne
          Upper Canada Chapter
          uccaomci.com
          #52433
          mr-asa
            Sorry guys, I might not have been clear, I more meant which brands.
            I’m probably going to go with, at most, a tach and speedo
            #52440
            wiscoboater
              Airguide, Stewart Warner, and Merc and OMC had their own logo’d gauges
              #52443
                Our 1964 Evinrude boat came with Aqua Meter instruments (ammeter, speedometer, compass)
                Fiberglassics library has info back to 1958: https://www.fiberglassics.com/library/Aqua_Meter
                Fiberglassics also lists westberg (westach) tachometers
                Faria made tachs & speedos (don’t know how early: no brochures at fiberglassics)
                You might find more brands at http://www.oldboatgauges.com/
                #52444
                mr-asa
                  I’ve already been looking for Airguide stuff as I found out about them a day or two back, some of the Stewart Warner stuff is nice, but dadgum the Aqua Meter stuff is cheap!
                  #52457
                  wiscoboater
                    VDO is another that was around in the 60’s, not sure about earlier. If you want modern gauges that look period take a look at the Sierra Black Sterling line. I’m using those in my wood boat.
                    #52495
                      in 1948 we had a Finson water speedometer that was accurate to the tenth of a MPH over a measured mile. . . 😎
