Home › Forum › Ask A Member › WH-7 vs KG-7 Impeller help needed.
  • #268851
    huntleybill
      I am working on a WH-7 Wizard and understand that it is a similar motor to the KG-7. However when I look on marineengine.com, it shows the impeller on the KG-7 to be on the prop shaft. The WH-7 is located on the drive shaft. The prop and drive shafts are different sizes.  Can someone please tell me what the part number for the Wizard impeller is?
      Thank you so much
      Bill
      #268853
      huntleybill
        Never mind…I found it. Thank you. Sorry to bother you
