Home › Forum › Ask A Member › Welding Vintage Cast Metal
- This topic has 12 replies, 3 voices, and was last updated 2 years, 8 months ago by
JOSEPH BRINCAT.
February 11, 2024 at 10:31 am #284825February 11, 2024 at 10:54 am #284832
I recently made the same repair.
Mig weld around the copper tube
then drill it out when your done.
Do a little on each side till you
bring it together to avoided melting
the tubing.
February 11, 2024 at 11:39 am #284834Like the way you went about this.
Also answered my thought of having to pull the jug off to weld.
Looks good!
February 20, 2024 at 6:32 pm #285202Did you have any problem tapping the hole?
T…
February 20, 2024 at 10:39 pm #285207
All I needed was a hole.
I didn’t have to thread mine.
Did you have a problem?
.A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
February 20, 2024 at 11:36 pm #285209Not yet, I’m reading that MIG welds can be difficult to tap so I was wondering how it went for you. I now see your repair was for the shorter bolt flange that allows for the use of a nut and bolt. Is that what you did?
I need to investigate TIG welding from which my reading appears to be easier to tap.
I’ll also take a close look to see if there enough room to nut and bolt this flange.
T…
February 21, 2024 at 11:15 am #285223
Mine is just a through hole for the screw
that holds on the coil holder/cover.
February 21, 2024 at 11:27 am #285224Okay, thanks.
February 21, 2024 at 12:11 pm #285226
Watch this video. After viewing a bunch of useless garbage
I found Tony. He offers good info on welding “To Cast Iron”.
He is not trying to be a You Tube star or running on and on
with a bunch of useless crap. 10:00 in his video applies to
to just what we are doing. His comments are what made me
decide to try this repair.
February 22, 2024 at 10:12 am #285242
Woops – wrong link.
https://youtu.be/pJimQ-QorOM?si=j1_Jwh4zLJGQwQsF
