Home › Forum › Ask A Member › Weber…scrubber
- This topic has 5 replies, 4 voices, and was last updated 3 years, 9 months ago by
JACQUES.
January 25, 2023 at 12:53 pm #271716
I searched a few big hardware store near me and could not find a decent long brush to clean up my carbonized Johnson cd18 lower housing and parts
found something at Home Depot in the BBQ section… a nice long stiff bruh for a BBQ which I sqeezed into a long brush with real nice stiff SS steel fingers
see pics
January 25, 2023 at 9:58 pm #271771A bottle brush from the dollar store will also reach down into the exhaust housing.
January 27, 2023 at 4:34 pm #271863I have heard that “Eazy Off” oven cleaner works great in dissolving carbon built up in the exhaust housing.
January 27, 2023 at 6:25 pm #271876ok thanks I hear easy off is very harsh on aluminum but yes in that section of the engine it is not to bad …a good flush will do to remove it
I have used my new colonoscopy brush with success. narrow in places but OK I guess I kept a bend in it which I will straighten .
stains remain but all the carbon has been vacummed out incl PH exhaust area . 🙂
January 27, 2023 at 7:06 pm #271880In my typical restoration projects, I have always used Easy Off oven cleaner to remove the carbon buildup in the exhaust housing. It can be harsh on the aluminum, so I typically let it soak for no more than 20 minutes or so. That’s usually enough to soften the carbon deposits that can then be removed with a good flush from the pressure washer. Here’s a pic of one such cleaning.
"Every time you remove a broken or seized bolt an angel gets his wings."January 27, 2023 at 11:16 pm #271907Bob nice job … I’ll keep that in mind for the next one. power washing in the basement is out …..Currently my lower housing is simply blackened but all the chunks are gone . installed a new base gasket and closed it up after doing the impeller.
unfortunatly for now my pressure tester is unavailable to test the GC but it… looks ok waithing for Spring 23 to test further and adjust the idle /fast needles
