Home › Forum › Ask A Member › Waterwitch twins
  • #7648
    ian
      Interestested in any information that can be offered on these Waterwitch outboards.
      #61634
      ian
        ian
          Motor number two…
          #61636
          ian
            ian
              It appears to me that they are both 571.22 1939 Waterwitch twins. One appears to have the wrong rope sheave from a 1936. I think between the two motors I have everything but the faceplate. I understand that they are hard to come by.
              Is either of the fuel caps correct?
              Does anyone have some information on these motors? Pictures?
              #61640
                I have one Ian. I can send you some pics of mine.
                I don’t believe the fuel cap on the first one is original?
                #61641
                ian
                  That would be great Chris thanks. Is your’s a twin as well?
                  #61642
                  ian
                    I’m hoping that the lower unit from one of these will fit the Waterwitch 1937 single 571.10 that Wayne has.
                    #61650
                    WAYNE
                      quote Ian:
                      I’m hoping that, too! I have very little information on these motors. I believe they have Bendix ignition. That’s about all I know. I’m sure between the two we can make a runner.
                      Wayne
                      Upper Canada Chapter
                      uccaomci.com
                      #61652
                        The exhaust is the only thing that’s different
                        from the 1937 so you have plenty of parts there.
                        The one rope sheave is a 1936 as you have
                        pointed out. The spacer between it and the
                        flywheel is also from a 36 and was only used
                        that year. Only 1893 twins were made 1936
                        and few survive. Quite a few parts are unique
                        to the 1936 like that spacer. I have one that
                        is mostly correct. Not at home so I can’t provide
                        pictures. These pictures are from the Waterwitch
                        website. This is probably the nicest surviving
                        1936 but is has a couple parts missing. The 1936
                        twin is the only one that’s uncommon. Later
                        models are not hard to come by especially
                        in the condition yours are in.
