Home › Forum › Ask A Member › waterwitch help
Viewing 10 posts - 11 through 20 (of 25 total)
  • #43502
    david-bartlett
      Also, when you push up on it, gas will run out of the bottom of the carb if the needle valve is open.
      #43503
      justwannafish
        Hmmm…seemed to have lost what I typed. Yes, the poppet valve is free as a bird. I did turn the mixture all the way in, the backed out 1 1/2 turns. Thought that would be a good place to start. I’m stumped because I figured if I primed the cylinder with fuel and have spark I should at least get something. Starting to think the spark isn’t hot enough?
        #43507
        david-bartlett
          Another thing, if the wiring is all original, the insulation could be cracked causing an intermittent short somewhere.
          These are pretty simple motors and fun to run. Mine starts very easily, usually on one pull. My spark plug is probably as old as the motor and still works.
          You can see it run at the end of this PTBC Video.
          https://www.youtube.com/watch?v=CdWDk7cS43M
          #43509
          justwannafish
            Thanks David. Love the sound of the motor, looks Iike fun. Ive checked the wires and points pretty well and I think they are fine, but will go through them one more time with this in mind. Do you happen to know the plug type for these old motors? It had an H10 plug in it but not sure it’s correct.
            #43514
            JOHN D.
              According to the old outboard book, the plug is a Champion H10. Set at 0.025", and the points are set at 0.020". This takes a gas/oil mixture of 3/4 pint oil to a gallon of gas.
              #43517
              justwannafish
                Thank you John!
                #43521
                  #43529
                  justwannafish
                    Good point Tubs, I’ll look into that also. Thanks!
                    #43582
                    david-bartlett
                      Just for fun, here is a picture of the spark plug in my Waterwitch.
                      justwannafish
                        That’s awesome! Nice patina…lol
