Home › Forum › Ask A Member › Waterwitch condenser replacement.
Viewing 10 posts - 11 through 20 (of 25 total)
  • #227604
      Probably one of these models!
      1936-to-1942-Waterwitch-models
        Are you sure it’s a Wico mag, and not an Eisemann?
        Waterwitch-Eisemann-Magneto-Part-Numbers
        #227612
          There should be a model number stamped somewhere. Either on the rope sheave or on the crankcase and probably starts with 571.XX.
          Waterwitches were built by several manufacturers so depending on the model, it could have either a Wico or an Eisemann magneto on it.
          #227615
          JOSEPH BRINCAT
            When in doubt , go with 0.22 mf condenser. This will work in most all applications. Try it, see if you get good spark.. no harm.
            #227619
            AnotherSteve
              Thank you everyone for sharing your knowledge and advise.
              DSC02070
              Ah to be young and foolish again instead of old and still foolish.
              • This reply was modified 5 years, 9 months ago by Mumbles.
              #227621
              AnotherSteve
                I can’t get to the motor for a few days to check out the mod. number and etc.
                #227623
                  Wico
                    Wico-X2981
                    AnotherSteve
                      Thanks again Buccaneer.
                      #227656
                        OK, it’s a Wico FW (Fly Wheel) 837B? I can’t find any listing for that particular model so you are going to have to see if there isn’t a part number stamped on the condenser itself somewhere.
                        Most, but not all, FW mags used a condenser (capacitor) with a rating of .16 – .20 uF.
                        Wico-Condenser-Values
