Home › Forum › Ask A Member › Water Witch twin
  • This topic has 15 replies, 4 voices, and was last updated 1 year ago by Tubs.
  • #301082
    boatdlr
      My mag plate is different as the coil and points plate are not the same as yours. The coil is riveted, and the points have a blade spring not a coil one. The points arm is rotted and fell apart. I tested the coil and found no shorts to ground and good continuity through the windings.  I guess in the end I can always make it a nice display motor so I’m pretty happy with how it looks so far.20251030_104121
      20251030_104121
      20251030_104121
      #301083
      boatdlr
        20251030_104121
        #301087
           If the rest of your motor is in that condition, you’re stepping into a big money pit and you can easily end up with little or no reward. After my experience trying to run one (for me) I’ve decided mine is best used as a display item. They are cool looking and even get the attention of people who have no interest in outboard motors.
          Post-3
          #301089
          boatdlr
            Yours is fantastic looking! A work of art. My motor is actually in pretty good condition and will display well. I really appreciate all the help you have been able to give me.20251030_104245
            #301096
            RichardMechler
              May I ask how that condenser was tested?  I must be doing something wrong..
              #301098
                Although you have some dents, your tanks are in good condition. You’re more likely to find them in this condition. With some effort you will have something that will get a lot of attention. They will be asking more about them so you have some homework to do.
                20251030_194013
