Home › Forum › Ask A Member › Water Witch Diagrams – Anybody ???
  • #281403
    BenKruse
      Anybody have a parts diagram for this little Water Witch?
      #281424
        No diagrams here, but is there anything particular you’re trying
        to figure out?
        I have a 1945 3 hp that I went through, and I’m guessing it’s
        very similar to yours.
        DSCN4643
        BenKruse
          Thanks!
          My lower unit has hardware that’s frozen in place and, I’m wanting to know what the pump consists of. Is it a (plastic or rubber) where it could fail or, is it a metal/gear-like pump. I know I’ll eventually need to drill and retap the lower but, I’d like to know so I can start keeping my eyes open for replacements if the pump is plastic/rubber.
          Ben
          #281430
            You don’t say what year or model your motor is, but if built like mine,
            it has a very different water pump. I can’t find photos showing I actually
            took the pump apart, but I believe it’s similar to some of the little Elgin
            outboards with the “carbon, sliding vane” affair.
            This is the water pump, and if I remember correctly, I had some trouble
            removing it from the driveshaft tube.
              Here’s the thread on my project in Current Project………
              https://www.aomci.org/forums/topic/1945-sear-waterwitch-3-hp-model-571-44w/
                Nice work!!
                #281454
                  I don’t get the pump at all.
