Home › Forum › Ask A Member › Water Pump Help for 1977 35Hp Evinrude (Model 35703H)
  • #295586
    Hi, Need some help here, I had to buy from the USA a new kit and housing as there is nothing available here in Australia at all for my model & I do mean nothing. I would like to know what seal fits around the shaft under the housing & where can i get it because there is nothing in the kit & whats the best way to fit this pump. A pic would be great but i’ll take anything available at this stage
    Thank You Grahame
    Ruse
    #295757
    David Stanton
      There are two of the same seals  there, one on top of the other.  Parts #23 at the link below.  Scroll below the exploded view to part 23 and click on it for ordering information (both OEM and Sierra aftermarket).  Not sure if Marine Engine ships to your country, but with the part numbers, you should be able to find someone that does.
      https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1977&hp=35&model=35702C&manufacturer=Evinrude&section=GEARCASE-35+HP
      #295788
        Grahame
        I’m not sure I understand what you are asking.  Give us the specific part number/item numbers of the “seals” you are referring to using the parts diagram Dave has posted a link to
