Home › Forum › Ask A Member › water in RD-19 manifold
  • #195901
    Geer Pyron
      I failed to plug two holes, the hose nipples near the carburetor, before giving an RD-19 a quick pressure wash. Should I worry about the little water that got sprayed in? Some did fo sho ’cause I turned the crank and a little dribbled out of the lower one.
      Thanks,
      G
      JMGP
      #195902
        Well, I am assuming you can’t start it to expel the water, correct? You sure don’t want that water to settle into any of the bearings…It might be easiest to pull off the intake manifold and fill the crankcases with light weight oil….Then turn it over to make sure the oil gets into the bearings….
        #195905
        Geer Pyron
          Correct. I can’t start it. It’s taken all apart. I did reinstall the flywheel and pulled it over with rope though. That’s when the water sputtered out of the nipple. Should I have done that with sprk plugs installed? They were out. I had taken them out to get a little more speed on the rope pull. But now I’m thinking I need that extra pressure.
          G
          JMGP
          #195906
            I would pull the intake manifold off and see how much water got in there. If it’s just a little bit of water you can spray a bit of WD-40 and clean it up. I wouldn’t want to rope the motor over and pull a big slug of water into the crankcase. If there is water already in the case, then as Fleetwin noted, you should spray some fogging oil into the case and rope the motor over to get that oil into the crank bearings.
            1982 Evinrude 25hp
            #195907
            Geer Pyron
              Dang! Was hoping I wouldn’t have to ‘cuase I always mess up the paint on those screws. But ‘ll do it. Thank you.
              G
              JMGP
              #195917
              RICK EICHRODT
                You might not have to take it apart. Get some kerosene and fill the inside of the block both through the spark plug holes and the carb intake. Let it soak…then drain. Fill with clean oil…..drain that. That should remove any traces of water.
