Home › Forum › Ask A Member › Water coming out of shift handle lever
  • #277783
    DrummermanBob
      I have a 58 Johnson FD-12 and I noticed water coming out from around the shift handle lever. Not a lot but was surprised to see it. Any idea why this is happening?
      #277784
        There is an O-ring on the shift shaft that is probably worn out.   The hole in the housing that the shift shaft passes through also gets worn/wallowed out a bit with time causing leakage.   Another member posted here one time with a fix for the worn out hole problem by epoxying in a section of thin brass tubing into the hole.   Mumbles or Tubs?
        1982 Evinrude 25hp
        #277785
        DrummermanBob
          Thanks for your reply. I see that o-ring on the parts drawing. Do I have to pull the power head to replace it? Assuming that shaft will rust if not taken care of.
          #277786
            On a 1954  7.5 hp Evinrude Fleetwin, I used per my notes…..
            Fixed shifter bushing with 15/32 x .014 brass tubing
            Not sure if all shifters of that era used the same size shifter shaft.
              Yes, you have to pull the powerhead to access the shift linkage and remove the shifter handle.   I just finished a resto job on and FD-12.   Here’s what the linkage looks like after you pull the powerhead.   Bend the locking tab down, remove the bolt and pull the shift handle out.
              Gearshift-Clevis
              1982 Evinrude 25hp
              #277790
              DrummermanBob
                Thanks Bob!
                #277793
                  Your motors look better on the inside
                  that mine do on the outside.
                  #277795
                    It’s a fairly easy fix using a short length of brass tubing obtained from a hobby store.
                    I’ll post some photos of the procedure later on today once I resize them.
                    #277797
                    DrummermanBob
                      Thanks!
                      #277800
                        As long as you have the powerhead pulled off, you might as well replace the O-ring in the carbon seal as part of the lower crankshaft seal assembly.
                        1982 Evinrude 25hp
