Home › Forum › Ask A Member › Washers for Cylinder Head Bolts
- This topic has 9 replies, 7 voices, and was last updated 7 years, 2 months ago by
aquasonic.
August 9, 2019 at 8:35 pm #181010
I’m looking for some washers, part #300399, to go with new cylinder head bolts on my QD-20, hopefully at a better price than $3.00 each at Marine Engine. I’ve looked at Fastenal and McMaster-Carr but can’t seem to find anything comparable to the OEM washers. These measure about 0.28 ID and 7/16 OD. Anybody have a source for these?
This topic was modified 7 years, 3 months ago by
Bob Wight.
August 10, 2019 at 7:23 am #181016Do have have an Ace hardware near you?🤔 they usually have something close, they carry alot of odd fasteners etc…
Rotary valve Johnson’s Rule!
August 10, 2019 at 9:57 am #181019Yes, my local Ace Hardware was the first place I looked, since they do have a lot of specialty fasteners. I made a quick pass through there yesterday and didn’t find anything but guess I’ll go take a longer look. Thought there might be another source I hadn’t found yet.
"Every time you remove a broken or seized bolt an angel gets his wings."August 26, 2019 at 5:19 pm #182044If anyone else cares or happens to be looking for these size washers, I found that a metric M6 washer is equivalent in size to the original factory washer.
"Every time you remove a broken or seized bolt an angel gets his wings."August 27, 2019 at 9:28 am #182096Bob, have you looked into hardware for Aviation? An AN960-4 washer fits a 1/4 in bolt better than hardware store washers. They also come in AN960L for thin.
Jim2Fast4Me
August 27, 2019 at 9:57 am #182101Find smaller washers with the correct OD and drill them out.
August 27, 2019 at 9:58 am #182102Jim, No haven’t tried the aviation route yet but did some googling after your note and I might try those on a future project. I bought a bag of the M6 washers already and they should work fine – the ID and OD are the same as the factory washers.
"Every time you remove a broken or seized bolt an angel gets his wings."August 28, 2019 at 6:14 pm #182218Bob,
there are uss & sae washers. Next time you may try a nut & bolt business for the sae “thin collar” made washers.August 29, 2019 at 3:44 pm #182273Boltdepot.com ?
Might want to try. I have used them in the past.
Pretty big selection.
Bob DAugust 31, 2019 at 6:25 am #182333If anyone else cares or happens to be looking for these size washers, I found that a metric M6 washer is equivalent in size to the original factory washer.
Last year I needed two 1/4” washers that were missing from a 1954 Evinrude cowl. Regular 1/4″ SAE washers had an O.D. that was too big to fit into the recess in the cowl. 6MM washers worked. They are a little bit snug on the I.D., but they had the smaller O.D. that was needed.
Improvise-Adapt-Overcome
