Home › Forum › Ask A Member › Vintage Outboard Gas Tanks
  • #2132
      I picked up two old outboard gas tanks at a flea market,
      and was hoping some one could tell me what vintage
      they are, what type / HP outboards they were intended for,
      and what the hose connection on the outboard end was like.
      The Champion tank has a single outlet
      http://www.grayhitandmiss.com/Outboards … g_tank.jpg
      The Mercury tank has an "air in" and "fuel out" ports.
      http://www.grayhitandmiss.com/Outboards … s_tank.jpg
      My 1956 Mark 6 Mercury has the same single line connector on the outboard
      as does my 1973 Mercury.
      Thanks for any info.
      johng
        The Tanks you bought are for 1953′ Mark 15 & 1954′ Mark 20 "only". Two line hose required with special male fitting.
        #21057
        20mercman
          The Mercury pressure tank was used from 53 through 55 for the Mk-15 & Mk-20. The 20H also ran on a pressure tank, but it was 3 1/2 gallon. Mercury used up extra pressure tanks in 55 with the Mk-25 and other motors set up with a single line and a trigger type pump instead of a ball. We had one on our Mk-25 that used to give my dad fits. Eventually converted it to a ball for priming and it worked much better.
          Steve
          #21060
          johng
            The other tank "Champion" is a 3 1/4 gal tank, fits 5 thru 16 1/2 hp motors 1953′ to 1958′ also " Majestic" outboards of same vintage. Hope this helps.
            #21072
              I had a couple of those Merc pressure tanks and sold them way too cheap as I figured out when I found out what the fuel connectors are worth.
              #21073
                The pressure tanks & fittings are valuable but the seal off fixture that covers the fuel entry port I have only seen in pictures.
                #21077
                  Wow…… great information. Thanks!
                  Only problem, I’ll have to look for a Mercury Mark 15
                  and a later, bigger Champion than I have, lol.
                  Anyone have photos of the Mercury hose "hook-up"
                  at the engine?
                  RICHARD A. WHITE
                    quote Jeff Register:
                    I have actually had one of those in my hands….belonged to the late Rob Glass…
                    classicomctools@gmail.com
                    #21085
                      Here’s the motor side connectors with wrong size brass fittings. I don’t have the tank connector to match.
                      #21086
                        Thanks Mumbles. I’ll keep my eyes open for those parts some day, and
                        maybe I’ll find that needle in the haystack too!
