Home › Forum › Ask A Member › Vintage OMC CRUIS-A-DAY fuel tank rebuild kit
- This topic has 22 replies, 9 voices, and was last updated 8 months, 3 weeks ago by
Steve D.
January 26, 2026 at 7:53 pm #303927
Need part number and source for my vintage 4 gal. OMC dual hose fuel tank. Mine has a metal push rod and diaphragm.TIA<!–more–>
January 26, 2026 at 8:21 pm #303929Look at this thread. It’s sure to confuse you (and me) but there’s some thought
there that you can make the “two hole” diaphragms that are on Ebay.Looking for help. Fuel Tank Diaphragm | Boating Forum – iboats Boating Forums
January 27, 2026 at 11:36 am #303941I haven’t seen all-inclusive OEM kit for pressure tanks. I have seen tank rebuild kits on Ebay that sellers have assembled. Because your tank is the older style with the aluminum push button, you will need the nine-hole diaphragm as opposed to the eight-hole diaphragm.
You can modify an eight-hole diaphragm to a nine-hole by using the old nine-hole diaphragm, that you show in your picture, as a template and making a hole for the plunger. Some of us only buy the eight-hole diaphragms because they are less expensive and easily modified.
The upper housing gaskets are made by OMC/BRP and Sierra, or you can make your own. They are made from thick cork sheeting. Lapping the upper housing mating surface until its flat will make it like new again. You get to start out with a new, clean, and flat surface that will seal up for decades.
The fiber washer screw seals can be reused if in good condition. NOS seals are pricey. I have been able to find fiber washers in bulk with the correct ID, but a slightly smaller OD and a matching thickness that work well. One thing about the kits I’ve seen is the screw seal washers are made of thin cork which can crush upon tightening, and they don’t look original if that is important. Use gasket sealer on the upper housing gasket and the screw seals.
Regarding the aluminum button/plunger, use Loctite Blue on the tiny brass nut and lock washer that secures the steel disk to the bottom of the diaphragm. The aluminum button also must be able to spin freely around the plunger. The tiny cotter pin in the button actually goes around the plunger rod in a groove that allows for the button to spin.
Improvise-Adapt-Overcome
January 27, 2026 at 12:23 pm #303944try vintageoutboard.com
January 27, 2026 at 12:24 pm #303945January 27, 2026 at 5:20 pm #303957The only OEM OMC kits for the pressure tanks are 377327 and 376455.
377327 includes the diaphragm, knob and washer. I believe this converts aluminum knob to plastic style.
376455 includes top gasket, gas cap seal and washers for mounting bolts.
All other parts are individual purchased.
January 27, 2026 at 7:58 pm #303960deleted.. call up Vintage outbaord folks see link above
January 27, 2026 at 9:52 pm #303963I got mine from Elton Duffy, aka “The Gas Tank Man” on facebook.
https://www.facebook.com/groups/49655829434/user/100084502405741/
Snip of his parts pic:
Here’s mine, restored very recently using parts from Elton:
January 29, 2026 at 8:27 am #304029Maybe I’m just thick but I’m just not seeing in any of these replies, part numbers, etc., anything exactly like what I have and need. Hopefully, these pics and description will clarify.
Tank I’m restoring is an OMC 4 gallon CRUIS-A-DAY JUNIOR, exactly like the one pictured here. The diaphragm I’m trying to replace is also shown. It appears to be all one piece and the metal air pump plunger attaches directly to it. Zoomed in pic of the top,assembly underside shows numbers 02572. No idea if this is just a casting number or a parts number. I’m really hoping someone can provide the with a rebuild kit parts number and a good source for it. Thanks in advance!January 29, 2026 at 8:33 am #304031Maybe I’m just thick but I’m just not seeing in any of these replies, part numbers, etc., anything exactly like what I have and need. Hopefully, these pics and description will clarify.
Tank I’m restoring is an OMC 4 gallon CRUIS-A-DAY JUNIOR, exactly like the one pictured here. The diaphragm I’m trying to replace is also shown. It appears to be all one piece and the metal air pump plunger attaches directly to it. Zoomed in pic of the top,assembly underside shows numbers 02572. No idea if this is just a casting number or a parts number. I’m really hoping someone can provide the with a rebuild kit parts number and a good source for it. Thanks in advance!System will only allow me to post 1 pic. But pic of the diaphragm I’m trying to replace is shown in my original post on this subject.
