Home › Forum › Ask A Member › Vintage Canoe Brackets
  • #170860
    GARY
      Here is a picture of the accessory canoe bracket for A35 and A45.It looks like the same bracket as the one for the A and A25 motors except for the bottom of the casting where it supports the down tube.You just might find that the one you have will fit your motor.You’ll just have to take the transom clamp off of yours to try it.
      #170863
      davidk
        Thanks for the responses and the parts diagram. Is the AC 35 bracket the same as the accessory bracket?
        Poking around in the barn, I found a J-65 that fits perfectly on the canoe bracket.
        IMG_0382
        IMG_0385
        #268072
        davidk
          Found another canoe bracket.  Different setup with a smaller diameter post and a bigger cup for catching the leg.  I think the wood block is a prior owner modification.
          IMG_8417
          IMG_8425
          IMG_8427
          IMG_8429
          #268078
          davidk
            The post has a keyway.  I wonder how that worked?
            IMG_8419
            IMG_8420
            IMG_8421
            IMG_8423
            #268180
              #268184
              davidk
                I could have saved a couple of bucks if I paid with eight 1925 Silver Dollars
                Screen-Shot-2022-10-24-at-11.33.32-AM
                • This reply was modified 4 years ago by davidk.
                #268330
                davidk
