Home › Forum › Ask A Member › Very old motor/new guy
  • #3109
    aaron-david
      Hello, I just purchased this old motor, and I was wondering if you guys could help me identify it:
      And another:
      It has the serial number of 100468 I think, and on the underside of the flywheel is the number 21 34
      There is a spot on where the transom clamps and the body is allowed to pivot that looks like it once had a name plate, but nothing now.
      I think it might me a Sea King made by Evinrude, but that is going from pics I found online.
      Hopefully you guys can help me, as this is my first out board to restore.
      Aaron
      #28057
      JOHN D.
        The #1 on the serial number is probably a 4. So you may have a model 400 Evinrude lightwin. It’s 4hp, made from 1931-1934. It takes a 6m spark plug, gapped 0.025, points gapped 0.020. One third pint oil to a gallon of gas.
        #28073
          There’s a lug sticking out of the crankcase where the tiller handle bolts onto, look on there for some numbers, my bet would be that it is a 7-digit number. If so, the first 3 numbers give you the model number. Hope this helps.
          Best,
          T2
          #28092
            Your motor is in the same family as the motor in this video.
            The timing lever is different on yours. It may be a Sea King.
            https://www.youtube.com/watch?v=W6Hs33FmOAo
            #28100
              Nice find for your first & welcome aboard! Be very careful not to break the fin on the bottom. Nice it still has it. Take your time & you will be rewarded! Go to Doug Penn for parts as he will help you, good guy to work with.
              #28114
              aaron-david
                Thank you guys! I have already started tearing her down, slowly but surely! It’s obviously an Evinrude 400 series, does anyone know of a good source for a manual? I have been looking at Doug Penn’s site and as soon as I figure out what I am going to need, that will be the first place to go.
                Again, thanks guys!
                #28134
                weedlessdrive
                  Good find! Welcome aboard with the of us addicts.
