Home › Forum › Ask A Member › vent screws
  • #264452
    CHUCK WEBSTER
      Does anyone have a source for green tank Merc gas cap vent screws. Or is anyone reproducing them?
      #264482
      need2fish
        Try http://www.oldmercs.com
        Fastenal may have a close facsimile, for example: https://www.fastenal.com/product/details/99274994
        #264545
        green-thumbs
          Sometimes you find a vent screw stuck in the plastic gas cap and the gas cap stuck in the tank. PB Blaster and a few days outside in hot sun and problem solved.
          Sometimes the know is broken off and remains of corroded thread are stuck in threads of plastic cap. Coat plastic with wax leaving thread clear. place cap in glass, add bleach. Bleach will react with aluminum and clear out the plug. Wax shields the plastic from dulling effect of bleach.
          I had some some aluminum threaded rod and ATTEMPTED to drill and tap knob. Takes a better machinist, but, the idea is workable. A simple jog to drill hole in rod for cotter pin that retains spring and chain. Thread is 1/4 x 20
          At one time reproduced caps and hardware were available at a price you could buy project motors for.
          It is possible to make both caps and vent screws from stock, but, that is a lot of time and effort as well as a waste of material.
          Louis
          #264558
          need2fish
            Find someone with a 3-D printer ? 🙂
