Home › Forum › Ask A Member › Variable Pitch Prop, aftermarket kit?
- This topic has 20 replies, 9 voices, and was last updated 10 years, 6 months ago by
outboardnut.
April 17, 2016 at 2:11 am #4055
I acquired an Evinrude Zephyr which had a adjustable pitch prop
controlled via cable and lever on the side of the engine.
I forget the brand name on the control plate… "Vari Prop"
or something perhaps. Will take photos tomorrow.
On the control panel it shows the forward speed ranges, but
also shows reverse. Did this really work?
Were they a desirable option in the day, or just another fad that
didn’t pan out?Prepare to be boarded!
April 17, 2016 at 12:58 pm #34944These offered variable pitch(speeds) and also neutral and reverse. Merely a flash in the pan. Didn’t last long on the market. They even offered them for some of the motors which had gear shift. Due to mostly non-shift motors for their applications, I would venture that products came out in the early fifties. One dealer still had most of his original stock in the early nineties.
April 17, 2016 at 2:39 pm #34946A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 7 years, 12 months ago by
Tubs.
Tubs.
April 17, 2016 at 3:34 pm #34947Tubs, that’s the same brand my Zephyr has, but mine has a
lever more like an old lawnmower throttle.
It’s Model FP 102.
Went to take photos, batteries dead. Put in spares, still
says batteries dead 🙁Prepare to be boarded!
April 17, 2016 at 6:40 pm #34953Interesting. Clever way to convert to FNR for outboards without. I probably would not want to drill holes to mount it in mine, though.
April 17, 2016 at 11:01 pm #34963Mine has a band that clamps around the lower unit so I believe
no holes were drilled on the bottom end, but believe they did
drill one hole up by the powerhead to attached the control cable
lever.Prepare to be boarded!
April 18, 2016 at 9:04 pm #35016Took some photos today of my new Evinrude Zephyr
with the Flex-Prop conversion. It seems to have good
compression, so hopefully it will be a runner some day
so I can see the Flex-Prop in action!
I’m unable to find any advertisements or information
on the Flex-Prop conversion kits.
Anyone have literature on these?
Thanks.
Both photos were "upright" on my computer……
What the Heck?Prepare to be boarded!
April 18, 2016 at 9:12 pm #35017Buc,
Coolest Zephyr I have ever seen. Looks great.
April 18, 2016 at 9:27 pm #35021Anonymous
I think our BBS is doing something to rotate the images….
When I select "view image" in FireFox, I get a right-side-up image!?April 18, 2016 at 10:38 pm #35025Ahhhh, Buc your pics show it clamps on. No drilling. Shifter looks good too.
Pics were upright on this end. -
